Careful, in most states you cannot touch the wire without a JW lice.  And if it was a union job, you cannot even have a screwdriver.
And for all you EE out there that think that only an EE can design,  Your too full of yourself. Reality check guys.  In all the BIG companies, CH2MHILL, Jacobs, Bechtel ect.  very few have a PE, and almost none of the designers have a degree.  For power study, yes an EE does the work, but for almost everything else, a designer does it.  Everything from cable selection and sizing, to cable tray fill and layout. Even most MEP firms only have one or two PE for 12 or more designers. As a designer I did it all.  One line, COMCHECK, SSCR, Arc Flash, Panel Sizing......... with the PE looking at my work at the end, stamping it, and sending it out.
To be told that only a PE can understand arc flash, or calcuate short circuit rating is insulting and arrogant on their part.
