 - Simi Valley, CA
How are you guys dealing with the requirements of 210.12 and 210.4(B) especially in custom homes?
Mostly two wire home runs or 2-2 cable?
John
You guys have legalized 'dope' out there correct?![]()
It amazes me how these guys got licenses-- of course it is probably the helpers doing the work with no supervision from the EC
Yeah, and these are not even nit picking items, pretty straight forward violations.
I'm not much of a nit picker, I'll point out the nit pickey stuff and tell them not to do that or clean it up next time.
I will give the contractor his due though, he called this morning and admitted that missing the TR receptacles was a mistake on his part and also the trims on the closet lights, but I did find out that like a lot of people he mistook the word "outlet" to mean "receptacle" so he doesn't have the lights on Arc faults and he had never heard about the WR GFCI receptacles.
Of course that kind of takes us back to Dennis's comment.
The times are a changing and you have to keep up. I wish sometimes that I could get all of the local contractors together and we would just have a short 1/2 code update class, but that doesn't solve my problem with all of the out of towners.
Being an old schooler like you, it saddens and amazes me the lack of training, technical skills, ethics, etc that I see on a regular basis in our trade and all the trades today.
Out of Towners. Where might they be from? Out of the country?
Isn't all of Ca on the same code?
Me too, but it's all about speed and the bottom dollar now. Quality has become an after thought.
You sure couldn't tell that by me. You have to remember that within a hundred miles of me I probably have 20 or more jurisdictions. And I tell people all the time, I don't care what they let you do in _________.
I do not believe that be out from this country have something to do with the trade cualification.
I'm from other country and I spend a lot of time reading books ,taking class and reading this forum in order to be a cualified electrician.
As a foreman that I am is so hard for me some times to explain the company that a code complian ,nice and nite job will take more time that a junky job.
Also I put all my effort to try to do evrything correct to be proud of my job and when the inspectors come there is no way to be sure that you did the correct job because some time the inspector have a different interpretation of the rules that most of other people have.
An exemple of this is the jumper on the water meter , I beleive this is no necesary if the point of connection of your EGC is made before of the meter on the street side of the water pipe ,but an inspector require me to install it in an inspection it was no way to explain him my point of view, guess what I install it in order to pass the inspection,now the next job I install it again because it is not so expensive installation to fight for and guess what, different inspector says it is not necesary . He was correct but the other force me to do it.
