JJWalecka
- New England
PVC coupling glued onto a stick of sch 40, Does putting PVC glue on the outside do anything at all? A waist of glue or does it actually help hold it better?
Agreed, this is what he is asking.I think the OP is asking about swabbing glue on the outside after the coupling is already on the pipe. It dose a lot of good..... if you own the glue company.
Glue on the outside looks good for the inspector. Since we are talking glue what is the difference in them. The supply house gives me clear, I know there is one for cold weather, when the HO gets it it's always grey goop, and of course the plumbers are into pink. Are all these glues from different horses?:?![]()
And as everyone reading this knows, pvc glue won't stick metal to metal
except the cap on the can
And if you man up it will stop bleeding from a cut.And as everyone reading this knows, pvc glue won't stick metal to metal
And if you man up it will stop bleeding from a cut.![]()
And make you sound like Steven Tyler for a few seconds as the acetone dissolves the tissue protecting your nerve endings prior to burning them off.
