Coastalguy1
- Virginia Beach, VA
The attached photo is of a (3) pump fuel dispenser island. The disconnect is fed from an 80amp 2pole 208v circuit breaker from a distribution panel. Note how the neutral is fused and then tied to the neutral/ground bar in the subpanel. I have never seen this. Is it NEC acceptable??? I typically see some switched neutral breakers when dealing with fuel islands.
thanks!
