electrofelon
- Cherry Valley NY, Seattle, WA
Ive been doing some work in a medical marijuana growing operation and most of the rooms need to be time clock controlled. All light are cord and plug connected and have 20A 250v plugs. There is a variety of methods employed there to accomplish this by the previous electrician that was in there, including a contactor controlled by a programmable wall timer, a time clock on the line side of a subpanel, and time clock fed by a branch circuit then feeding some outlets. Each room takes 30-40 amps at 208 single phase, but due to the loads being continuous and providing for expansion, 60 amps would be nice, so the 40 amp rating of the time clock is a bit of a problem. I will be doing another grow show next week and am trying to come up with the most economical and uniform way to do this which led me to this idea and question: Is there any code issue with using a time clock to switch one leg of a feeder that then feeds a sub panel that feeds 250 volt outlets? If this is ok code wise my plan is to run two #10 feeders (single phase 208v no neutral) to a DP time clock where one leg of each feeder will be switched and then each feeder will hit a small panel with 2 20 amp breakers and two 20A 250v receps. This would get me 60 amps total with a minimal material bill, minimal install time, and the convenience of one time control. I couldnt find a violation but it does seem odd to me for some reason, even though it is done with electric heaters a lot, but here I have receps......
Thanks
Thanks
