- Tennessee NEC:2017
- Semi-Retired Electrician
If the pool has any electrcial equipment, then the code requires a connection between the EGC and the pool bonding system. That is a "direct" connection to the electrical grounding system, in my opinion.
You will have to show me that code. Only thing required is a bonding lug on the equipment to the bonding system. True if the case of the equipment has the EGC bonded to it, then there is a connection.
I don't know anywhere in the code, other than a pump motor that is double insulated, that says to tie directly to the building grounding system, and that is through the EGC.
