I recently failed an inspection on a 30 amp residential water heater.  Inspector claims that I have to re-identify the white wire as a non-grounded conductor.  Now in all fairness, while he just might end up being correct for some strange NEC reason, logic tells me that if the black and white wires of a 10/2 MC cable are landed on a 2-P-30 amp circuit breaker, wouldn't it seem logical that the white wire is a non-grounded conductor ?  Not to mention, I can't think of any 30 amp, 120 volt residential appliances that would require the white # 10 to be landed on the ground bar.  Normally I wouldn't care if it was a local job but, as luck would have it, I have to travel 1 hr and back for a 5 minute job to mark a cable.
A simple phone call to me would have sufficed.  I could have made the correction the next time I was in the area.  IMHO, just a clear cut case of an inspector over-extending his authority by slapping on a red sticker and giving my customer the impression that I'm the south end of a north bound horse.
