 - Placerville, CA, USA
 - Retired PV System Designer
But have you seen a "good" waveform at the input to two identical transformers and a distorted waveform and lower than expected voltage on the unloaded secondaries of those same transformers?Seems a little tenuous to me.
This, for example, is my voltage at home:
I've seen this and worse on numerous sites unrelated to ferro-resonance.
That is the specific condition we and the OP are trying to understand.
AFAIK the OP has not been able to check the loaded output of the transformer(s), although that sounds like a promising thing to try.
Oh, and is there anything which may be related to the fact that these are autotransformers (boost)?
