jeff48356
- Livonia, Michigan
For a bathroom fan/light/heater unit, the manufacturer's directions call for a separate 20-amp circuit. However, the heater is 1300 watts, fan 145 watts, and the maximum bulb wattage is 100, for a total of 1545 watts. Now, the only time it will be 1545 watts is IF a 100-watt bulb is used. I would personally never use one, but rather, a CFL which is only about 20 watts. This would put the entire unit below the 1500-watt limit for a 15-amp circuit.
Can I wire this with a 15-amp circuit as long as I only use a CFL in the light? Or would I still be required to use a 20-amp circuit?
