gar
- Ann Arbor, Michigan
- EE
130928-1608 EDT
Sparty D:
Do the RS485 paths have isolation?
So you have a homemade 12 V DC power supply. What is the maximum load current on the 12 V DC output? What is the regulator chip? Are you using full wave rectification? I assume a capacitor input filter. What is the size of the filter capacitor? When the power supply is at full load and input AC voltage is nominal, then what is the average DC voltage across the filter capacitor, and the ripple voltage across the same capacitor? What is nominal AC input voltage at the power supply? What is the outside surface temperature on the regulator where it attaches to its heatsink at full DC load, and nominal AC input voltage?
At what input AC voltage does the minimum filtered DC voltage at full load output current drop below 16 V (this allows for a minimum voltage across the regulator of 4 V)? At full DC load what is the capacitor voltage when AC input voltage is at its maximum likely value?
If your load current is 1 A and the regulator drop is 4 V, then regulator power dissipation is 4 W. If at maximum AC input voltage the capacitor rises to 20 V, then regulator dissipation is 8 W.
You referenced 97 V as a minimum dip, and possibly 1 second long. If your filter capacitor is not large enough, then you could loose 12 V regulation. You may want a rather large filter capacitor, or a backup battery integrated into the power supply.
Are you getting data errors from the RFID door units, or do they just go into "never-never land"?
What is a PTAC?
			Sparty D:
What is a PTAC?
