bullheimer
 - WA
searched and no posts with ovens in the title so...
nothing says you can't put an oven and a cooktop on the same circuit. i know you can put an oven and a cooktop on a 50A circuit, but those two take alot of juice. i have this customer that bought a 240V microwave that takes 15A. the oven says it takes 17. i know that is 32A because i can do simple addition, and i know 10g wire is good for at least 35A. i also know i can't fuse the 10g at more than 30A.
WHAT says i can't supply them both from the same circuit? are they continuous loads? is there no reductioins, like with multiple ranges or dryers? i am sure there is something that wont let me do it, and am planning on running a new 240 ckt tomorrow. (the stupid micro requires a neutral!).
the reason is the customer told me to run a 20A 120 for the micro above the 30A oven outlet, which i did. but it is of no use now since fool customer went out and got this 240V micro. it is NOT a Bosch, which lets you feed one from the other, either. they are both kitchen aid. and dig this: Kitchen Aide (whirlpool) factory HAS NO, ZERO, TECH SUPPORT!!!!!:thumbsdown: all they have is NO instructions for this with the micro, but the oven DID have instructions saying to put it on it's own circuit breaker.
