petersonra
 - Northern illinois
 - Semi-retired engineer
Fair enough.
Here is a pretty typical occurrence, we get hired to go to a store to add a bunch of receptacles.
Why?
Because either a fire marshal or electrical inspector was checking the store and finds a ton of extension cords supplying display items might be the TVs, or it might be seasonal displays etc.
The FM or EI will cite them on using cords as a substitute for permanent wiring. The store can either comply or if they stall long enough the FM will threaten them with closing the store. I wont say they close places often but it does happen enough store mangers get the message.
I agree such a situation might well be a fire code violation. That does not mean the it is a NEC violation as you were previously claiming.
One might also be able to credibly argue it is being used as a substitute for permanent wiring in such a situation.
neither would apply to the situation being discussed in this thread, nor does it have anything to do with whether it was a factory assembly or not.
