mjf
Veni, vidi, vici!
Mega dittos. Enough already.Are we not professionals? Cut the screw and move on? :?
How many posts does it take to solve this issue? Ii take it you have that problem with hundreds of these screws. What have you come away with that would make your job easier that you haven't figured out already? I don't think it takes nuclear rocket scientist to figure but over 7 pages of posts?One little bitsy screw may not be a problem, but hundreds of little bitsy screws add up to being screwed big time.
Sent from my XT1080 using Tapatalk
If you set the posts per page to the maximum of 40 you are only on page 2 right nowHow many posts does it take to solve this issue? Ii take it you have that problem with hundreds of these screws. What have you come away with that would make your job easier that you haven't figured out already? I don't think it takes nuclear rocket scientist to figure but over 7 pages of posts?
I'm all out of dollars, will you accept chickens or goats?I bet $1 a nuclear rocket scientist does not know how to trim a 6-32 screw and properly fit it on a decora cover plate to be flush with a tiles back splash. And NRS thinks nuclear is complicated?? he should try to cut a screw for a change.
How many electricians does it take to screw in a switch plate?
so far 69 just to come up with a process. The screw is not installed yet.
We need drawings
We need therapists.We need drawings
I was taught if the screws are white.....thread them into my cutters and cut-em.
If they're ivory.....cut a notch in the tile.
Any other color..... flip a coin.
We need therapists.
We need therapists.
I was taught if it was not White....change it to White, cut and move on.
You can say that again.
We need therapists.
