wirenut45
- Camden county NJ
I don't want to sound like a wise a**, but if you need to ask that question, then you should not be using this tool.
[h=2]Treatment of New Members[/h]To all forum members, I am formally requesting that you no longer publicly question new members qualifications for posting here.
Keep in mind that all new member posts have already been approved by a forum moderator before they show up on the forum.
If you feel a new member is over their head please exercise one of two options.
1) Notify one of the Moderators, I suggest you send a PM to one of us with a description of the problem you see with a post. We will gladly discuss it with you.
2) Do nothing, ignore the post and move on.
The reasons for this should be self evident, we are going to chase away new members if they feel they have to justify their qualifications with the entire membership at large.
Not to mention many times it is just plain rude.
Bob
2007 Chief Moderator Mike Holt Forum
Insulated refers to whether the barrel of the connector is insulated or not.
If you have a connector with an insulated barrel you use the INSUL part of the tool to crimp it, and vice versa.
Note that the shape and size of the crimp is different because you need a different crimp for insulated versus uninsulated barrels.
Did the thing not come with instructions?
Since there is no downloadable user manual for those strippers on the Klien site, it's possible they don't come with instructions. Not all tools do, especially hand tools.
I went and checked the web site and I noticed there were no instructions either. I thought that was a bit odd. Hand tools that come attached to a piece of cardboard often have rudimentary instructions printed on the cardboard.
Also, the 7-8mm auto portion is for automotive spark plug terminals. How many sparkies know that?
I did not know that.
I have yet to see a simple crimper able to crimp insulated terminals without damaging them. It takes a ratchet crimper with the appropriate die. The 1010 really kind of sucks for crimping anything, except maybe the web of your hand. The best feature is the bolt cutters.
Since the White Book says you have to use the crimp tool specified by the terminal manufacturer, you probably can't use that tool for any terminals per 110.3(B).
Totally agree. That's what we use.I am not a huge fan of plier type crimpers for any purpose. A ratcheting type crimper gives a much more consistent and reliable crimp.
From the UL Guide Information for Wire Connectors and Soldering Lugs.do you have a link to this?
Use of specific tools ? A specific tool and die used to assemble a wire connector to a conductor is identified on the connector, or on or within the unit container of the connector. The identification consists of a catalog or type designation, color-coding, die index number, or equivalent means. Color-coding of the crimp barrel is common.
White book (2012) ZMOW: ZMVV:do you have a link to this?
INSTALLATION INSTRUCTIONS
Use of specific tools ? A specific tool and die used to assemble a wireconnector
adapter to a conductor is identified on the wire-connector
adapter, or on or within the unit container of the wire-connector adapter.
common
This category covers crimp tools suitable for use with specific Listed
Grounding and Bonding Equipment (KDER), Electrical Quick-connect Terminals
(RFWV), Wire Connectors and Soldering Lugs (ZMVV) and Wireconnector
Adapters (ZMOW) in accordance with the Classification Mark and
a compatibility list provided with the tool.
The inside cover of the tool storage case or a permanently attached label
to the tool itself contains a compatibility list that tabulates the company
name and catalog number of the crimp tool and the company name, catalog
number, wire size and number of crimps of the applicable Listed grounding
and bonding connectors, quick-connect terminals, wire connectors and
wire-connector adapters for which the crimp tool has been investigated.
Multiple crimping operations ? The number of crimps necessary to
make a connection using the specific tool is identified on the connector, or
on or within the unit container of the connector. Absence of information
implies a single crimp
Those devices investigated and intended to be secured to conductors by
crimping are additionally marked to identify the required crimp tool, die,
and number of crimps.
ZMLS (tool) refers to RFWV Electrical Quick-Connect Terminals, but no back reference to ZMLS from RFWVFactory-installed field wiring connectors requiring the use of a special
tool (such as crimp connectors) are provided with instruction
I apologize for my response, it was indeed rude, and I apologize to all here. I have sent a personal apology to wirenut45, and I am contrite. :ashamed:
There are ratcheting crimpers that actually cold weld the conductor to the terminal. The pair I saw without dies was $180. That's the only crimper I saw that would make a solderless crimp that was more reliable than a properly soldered one.
If I do have to use a plier type crimper, this is the one I prefer:
That is primarily what I use. The application as well as how well failure may be able to be tolerated may make a big difference in just how bad you really need something better than this tool - JMO. Most low power general purpose applications this works with few failures. If you are a serious panel builder - you probably get something better.Those would be the only non-ratcheting crimpers I would use as well for larger wire sizes and it would be a good recommendation to the OP instead of the stamped metal ones. I think you can get a set like that for under $40. I do have an old set of stamped metal crimpers branded by AMP for really small wires and open type crimps where the crimp gets folded over and embedded into the strands, but that's a different animal altogether.
