- NE Nebraska
Originally Posted by PetrosA So according to 394.56, if I run out of wirenuts, I could still do a code compliant install using solder, friction tape and vinyl tape in my JBs and the inspector would have to accept it? Cool
I believe if properly done that it would be compliant. You might have an argument with the inspector though as it seems that some regard anything rare as being prohibited.
The section he quoted was a section on knob and tube wiring - soldered connections was the common practice with that wiring method, it was open splicing, but was supposed to be in free air and the porcelain knobs held it away from framing members. If you were bringing things into a box which typically was only done at switches or outlets then other connection methods was acceptable. Of course you generally needed insulating tubing enclosing the conductor where it entered the box.
