 - Massachusetts
I would agree, however I mentioned it because ...
I saw that as well and that leads me to believe there would be no provision for that frame size breaker. The sub feed spot would be special order and if there were no intended loads for it why would they do that?
One other possibility is if it has feed through lugs on it or if the main breaker has open lugs left for parallels he could easily leave the panel in place and simply continue the feeder into the transformer.
Like you I dislike the idea of doing away with a perfectly good panel.
