GlennG
 - Hicksville, NY
About 6 months ago I installed a Nu Tone 110 CFM exhaust fan/ light combo over a shower. Fan is listed for application as long as there is GFCI protection, which it has. They started to have a problem with the GFCI tripping mid shower, turning everything off, then I realized that the thermal protection for the fan was also tripping, sometimes just the thermal, other times that and GFCI also. I swapped the guts on the fan and all was good for a while, then it started Happening on  a consistent basis. I changed the guts a second time and it's even worse then the first swap. I know that they take long hot showers. My thought is the fan is being overwhelmed with steam causing the thermal to trip on the motor, and or GFCI to trip. Also I forgot to mention, fan has new duct to fresh air.
My questions are have anyone had a similar problem?if so how did you remedy the situation? I need to come up with some kind of solution. I was thinking maybe install a higher quality fan light combo? Maybe a Panasonic, or Delta. This whole thing is becoming a little ridiculous. This will be the last time I put a fan light in a shower. Also FYI all wiring in bathroom is new. Any guidance would be greatly appreciated. Thanks.
