Agreed Roto Split is best I have foundI would guess that Roto-Split is the best selling cable cutter.
Another vote for Rotospilts but this model with the extra lever
It is better when working with multiple sizes of MC, you don't have to adjust the knob to change sizes.![]()
The one you posted I've had better luck with, for some reason the clamp type has always broken on me. Not that I do a lot of MC cable these days:lol:I agree don't use the one in the photo that I posted.![]()
Couple of fun games with rotosplits.
Reverse the blade on a coworkers rotosplits and watch them to try to use it.
When a coworker steals one of your spare blades for his own rotosplits take it back but install the cardboard cut of the blade that comes in the blase storage space in its place.
BTW, BX Cutters work better than dikes......but if it's just aluminum armor, I break it open and use my dikes.
Greenlee sells this one.
I don't like it, the parts fall out that grip the cable.
The Greenlee model is the only one I have used, so I am used to it, but can't really compare to the roto split either. When I worked for another company we had an ideal stripper that wasn't a rotary type, that actually was faster then the rotary cutter, but I think it had less range of cables it worked with - but we pretty much only ran 12-2 and 12-3 and it worked great on both. It was more of a pliers type device - kind of hard to describe, maybe they still make it and I can find a link to one.I like the Greenlee cutter better. It was the one I used first.
Old habits are hard to break, or is it you never get a second chance to make a first impression?
Can't speak for roto splitter but the greenlee has an adjusting screw to set the cutting depth, I can't recall ever never needing to adjust it though.I hate roto splitters unless im cutting through hard bx cable. Otherwise i use my dikes which is fast and easy especially if your making up a rat nest of a j-box full of MC cable... Roto splits eat up time like crazy and some eat into the sheathing of the wire too much and eat through to your conductors... not good.
