nicholaaaas
- Baltimore
Go play in the panel and say its all good now
Sent from my Nexus 9 using Tapatalk
Just got a call today about a woman who's daughter has issues with electromagnetic field's . Going there tomorrow morning and I'll see what's up. I am seeing more and more people like this. Sort of like a craze or fad -- like Gluten free---![]()
Here's the link to that document, in case anyone is interested:I won't try to give all the results because shortly after, and since that time there have been many, many studies done. I did run across a simple document by LIPA, called "Magnetic Field Levels Around Homes" that has some good easy to understand info.
You have a guass meter right? Those are awesome in times like that :thumbsup:![]()
This, IMO is one of the best videos ever made on mitigating EMF:
https://www.youtube.com/watch?v=W6SyJFPYM8c
Did you know that Karl Riley is a member here and also a moderator
I wish Karl would have talked about the studies on electromagnetic field's a bit to explain why he feels that electromagnetic field's are not good. We do know that 300.3(B) eliminates magnetic fields when conduit is in use but we have an exception that allows non ferrous raceways to run the neutral separate from the feed. 300.3(B)(3)
Just build the place to governments 'Tempest' specifications. We have done some of these. No electrical inspections and not NEC compliant.
http://en.m.wikipedia.org/wiki/Tempest_(codename)
How are they wired though? If you can share the none confidential methods in reducing EMF?
Sorry I had not seen your post.
I was not a worker on the job but I was asked questions about some of the specs and how they complied with the NEC. That was easy, the specs required violating the NEC. One of the items I remember was that none of the conduits passing from the unsecured space into the secured space could be electrically continuous. They had to use some specified or provided fitting to break the continuity of the raceway at the wall.
Once inside I think we used MC however as I said I was never on site.
Basically if the protected area is a Faraday cage, any unprotected wire penetration including a conduit EGC, can allow RF to penetrate the cage.Its ok
No idea what breaking the conduit up does, but if it gets the job done why not.
EMF reception:
Back in 1955 or so after I had my first silver tooth filling, my uncle showed me how you could take a piece of aluminum foil and an old motor brush and hold them between your teeth and actually hear the local AM radio station.
You had to be able to make a point contact diode as one part of the circuit (not impossible with properly blended amalgam, but much easier with a galena inclusion) to detect the AM.That hurts my teeth just to think about it. Over the years I have had most/all of my silver fillings replaced, but I still remember how it feels to bite down on a piece of foil with silver fillings. OUCH!
I had a crystal radio set as a kid; same principle, I guess.You had to be able to make a point contact diode as one part of the circuit (not impossible with properly blended amalgam, but much easier with a galena inclusion) to detect the AM.
And I think many local AM stations were higher power back then.
Yup. Only it used a high impedance headphone to generate audio. It is not nearly as clear how the modulated DC on the tooth is perceived as sound.I had a crystal radio set as a kid; same principle, I guess.
