I have read this doc a few years ago, and it is correct that allot of current does flow in the earth, many years ago I proved a point that our low frequency power current can be sensed around the whole earth, as I took a spectrum analyzer and put two rods into the ground 60' apart, and was able to see our 60hz and Europe's 50hz on it as well as a very weak 25hz most likely coming from Philly area, I also had hits at 72hz and 92hz which used to be used to communicate to subs around the world 72hz is ours and 92 was the Russians frequency, there were also other hits I can't recall but I couldn't identify them, our sub transmitter is up in upper Michigan and I was in Florida at the time, if we can realize that as a whole the earth is a perfect conductor very close to 0 ohms then we can understand why this is possible, it's our small area of connection that has the high resistance, so we know that current can travel around the earth, but between and two points will be very very low voltage, higher frequencies do not follow this theory as they are filtered out, so the fact that this doc tells me that the current in earth is RF is a myth, it just cant happen otherwise wee would be able to use the earth as a way to communicate around the world which we know can't happen, so some truth and much myth is what your reading.
