bobby ocampo
250.20 (B) Alternating Current Systems of 50Volts to less than 1000 volts. Alternating-cutrrent systems of 50vollts to less than 1000 volts that supply premisses wiring and premises wiring systems shall be grounded under any of the following conditions:
(1) Where the system is 1-phase and can be grounded so that the maximum voltage to ground on the ungrounded conductors does not exceed 150 volts
(2) Where the system is 3phase, 4 wire, wye connected in which the neutral is used as a circuit conductor.
(3) Where the system is 3phase, 4-wire, delta connected in which the midpoint of one phase winding is used as a circuit conductor.
QUESTIONS:
FOR 250.20(B) (1)
a) Is the system allowed to be UNGROUNDED if the system is 3phase?
b) What are the incidence where a system cannot be grounded?
c) If the system is single phase line to line and 120 volts only, will the Code allow it to be ungrounded?
FOR 250.20(B)(2)
a) If the system is 3phase, 3-wire, wye connected in which the NEUTRAL is NOT USED as a circuit conductor, will the Code allow the system grounding to be UNGROUNDED?
FOR 250.20(B)(3)
a)If the system is 3-phase, 3-wire, delta connected in which the midpoint is NOT USED as a circuit conductor, will the Code allow the system grounding to be UNGROUNDED?
QUESTIONS:
FOR 250.20(B) (1)
FOR 250.20(B)(2)
FOR 250.20(B)(3)
