Hello,
Came across 210.52 (G)(1)
Thought I was paying attention during the ceu class, but for whatever reason missed this..
Am I understanding this correctly..
Attached garages must have a receptacle outlet and that outlets circuit can not supply exterior lighting or receptacle outlets..??
That receptacle circuit however can supply anything else in the garage or rest of the house that doesn't have it's own requirements? ...
Detached garage if has electric must have a receptacle.. and again, that circuit can not feed outside lighting outlet or receptacle...??
If so.......... sounds like it should me mandatory to say that Two 120v (or one multi wire branch) circs are required to a detached garage with electric power (one for inside outlets, one for outside stuff)
If I'm correct in reading this, what could be the reasoning behind this...
As a note for attached or detached garage... it say's that branch circuit "shall not to supply outlets outside of GARAGE"..... SO...... if attached, that circuit should also be able to feed outside receptacle outlets and lighting outlets if those outlets are NOT by the garage, correct? AND if a detached garage that had some storage area constructed to it... should external outlets from that circuit be permissible located at that part of the building?
Thank you
Thank you
