david
- Pennsylvania
So what you are telling me is that the CMP sees the issue and has not fixed it?
Regardless it currently says what it says and IMO there is nothing commercial about a volunteer fire station.![]()
Well its more commercial than it is residential.
If I was defining the garage portion of this facility I would go to the definition for commercial garage in the NEC.
Not finding a definition there I would go to other codes that deal with the facility if having no luck I would than go to Webster’s ‘
In my state it is simple the state law says its commercial
Edit: take the same building not under municipal ownership. private use and see if you could build it in a area designated residential without a variance
