I am not claiming it is residential, I am simply saying it is not commercial.
I think it is clear you would, in my personal opinion that is a mistake.
I believe the correct order is NEC first for definitions than the dictionary the NFPA recommends.
I posted the definition of commercial and it does not fit the volunteer fire station.
does it really say volunteer fire stations are commercial?
Or are they simply in commercial zones?
Again I am not calling it residential or a dwelling unit.
I have to go to the building codes first since it is a building classification under the building code not the NEC.
Then i would apply the NEC to how the building is classified, then classify the area's in terms assocoated with the wiring and electrical classifications under the NEC.
From the building Code 2006 in more recent versions of the building code the NEC is no longer considered a standard by reference but rather is the Electrical Code for non residential buildings covered under the Building code. So definitions found in he NEC as it pertains to electrical provisos would be applicable as well, as long as there is no conflict.
201.3 Terms defined in other codes. Where terms are not
defined in this code and are defined in the International Fuel
Gas Code, International Fire Code, International Mechanical
Code or International Plumbing Code, such terms shall have
the meanings ascribed to them as in those codes.
201.4 Terms not defined. Where terms are not defined
through the methods authorized by this section, such terms
shall have ordinarily accepted meanings such as the context
implies.
Comment from the building department: For profit or not for profit (volunteer)is not considered. A fire station would be classified as type B category type B is commercial and a garage in a type B occupancy would be a commercial garage.
Further comment the building department would classify this a commercial garage and would suspect the NEC section 511 would be applicable to a commercial garage.
