bullheimer
- WA
i just got a correction to put a LABEL on a stinkin gen set input recept. are you kidding me? bonded or floating neutral system? does it MATTER? The recept has FOUR wires in it no matter what so who the hell cares? i think this is another PANT LOAD!
2014 NEC 702 .7 -(C)
Where a power inlet is used for a temporary connection to a portable generator, a warning sign shall be placed near the inlet to indicate the type of derived system that the system is capable of based on the wiring of the transfer equipment. The sign shall display one of the following warnings: WARNING FOR CONNECTION OF A SEPARATELY DERIVED (BONDED NEUTRAL) SYSTEM ONLY or WARNING FOR CONNECTION OF A NONSEPARATELY DERIVED (FLOATING NEUTRAL) SYSTEM ONLY
All i see this is another way for the state to get more money out of me, for Trip Fees. No matter what the system is an Interlock is going to keep from backfeeding either one of them. iF they are worried about somebody not knowing if they are feeding a sub or a main panel, then why don't they require the label to say THAT instead of this BS about bonded or floating Ns?
RANTING!!!:rant::rant::rant:
