mbrooke
Batteries Included
- United States
- Technician
Depends what the OP intends to do. Started sounding like he wanted to make his own recipe.
Or doing what most POCOs do, getting the most out of anything which require "what if" scenarios. Personally I dont think the voltage drop upon inrush will be as bad as the OP thinks. Ive seen 25kva banked pigs run store fronts with many large AC roof top units as well as sewage lift stations no problems. The low Z of most utility transformers especially pole pigs is no accident as these are frequently overloaded into oblivion.
Edit: the OP is asking about a padmounted unit, but those are not exempt from this philosophy either.
