mbrooke
Batteries Included
- United States
- Technician
You see some spacer cable in cities/towns here but never in the rural distribution systems. Something tells me it cost more then what it may save in situations described here. The lines hitting each other, is something that doesn't happen a lot, but does happen. Occasionally you will see some spacer devices in select areas where maybe wind, ice, maybe both seem to be more frequent of a problem, but is not widespread use of such devices.
The ice storms we had about 10 years ago would have taken down spacer cable. It wasn't just conductor that came down in those storms, it was many miles of poles broken off near the ground.
Spacer cable varies greatly depending on the utility, service territory and desired outcome. Generally, areas which have trees see far more spacer cable where as, for example, in mid western utilities spacer cable is non existent. Spacer cable does cost more, however depending on a variety of factors it can be worth the initial cost.
Large trees and exceptional ice accumulation will take down spacer cable, but with the right design mild to moderate events are handled with higher reliability. Limbs and vegetation can come closer to spacer cable then conventional construction, but large limbs at risk of falling should be removed. In terms of handling severe events like a large tree coming down it is often advised that the messenger be sized such that it will break first before the pole snaps at the base, and likewise where severe ice accumulation may occur the messenger be large enough and the pole thick enough to handle it. The messenger size and pole size is weighed against cost vs a contingency probability analysis. A word of caution though, In applications where the spacer cable is likely to broken, twisted, or encounter very serve conditions repair cost goes up since fixing the spacer cable becomes a complex job with more parts involved.
Even several miles of 115kVA transmision line on two pole structures went down, it wasn't so much broken cross arms, insulators, etc. the poles broke off near the ground and once it got started kept going like a domino setup.
In that case nothing will hold up. BTW, not to nit pick but its killo-volts or kv rather then kva. 115kva (115,000 va) is not a lot of power.
