wire
enireh
Canyon Lake,TX
is there a single conductor direct buried wire? Can I buy just one conductor to be put in the ground? I need to add a # 6 for an existing three wire 200 amp service going to a residential sub panel
iwire
Massachusetts
What do you mean by add? How are the other conductors ran?
rippledipple
New Jersey
Electrical contractor
uf wire
uf wire
no you can't,all feeders would have to be in same jacket or conduit etc.in case a fault occurs between any feeders!!!
enireh
Canyon Lake,TX
wire
they are in ser cable 150' of it. from outside they go through 2" pvc, under the house about 40' in the pvc stops and the ser continues on up into the panel, and its three conductor so I am adding a # 6 ground
You must not have SER. SER means three insulated conductors, and 1 bare conductor (five wire is available and also called SER). Maybe you have SEU?
