mboutal
- Columbia, SC
Hi All,
Have you ever seen a High Resistance Grounded Unit System w/ ground fault enabled on breakers. What I know is with radial ground fault CT's in breakers, you cannot detect that small current (5-10A). You usually need to disable those CTs and have an external CTs with a relay. I need to know why is required sometimes to have GF protection on breakers with HRGU. HRGU is there to reduce the amount of current at the time when fault occurs. Could you please describe how HRGU works scientifacly with examples? I need to make sure I understand this system theoretical, please help! I also want to know why some they want with ground fault protection, you trip the breaker responsible on the zone where the fault happens.
Thanks a lot,
Thanks a lot,
