- Chapel Hill, NC
- Retired Electrical Contractor
I was told that the NEC held a final vote on the 2020 nec but I don'see it on the site. Does any know if this is true-- I got it from someone locally
210.8 New GFCI requirements.
1. Dryer will be required to be GFCI protected
2. Range will be required to be GFCI protected
3. A/C unit will be required to be GFCI protected
4. Electric Furnace if installed in crawl space, garage, or basement and 50 amps or less will be required to be GFCI protected
5. Water Heated if installed in crawl space, garage, or basement will be required to be GFCI protected
6. Basement receptacles will be required to be GFCI protected (unfinished or finished)
210.12 New AFCI Requirements
1. All 120 volt 15 and 20 amp circuits in a dwelling unit will be required to be AFCI protected 230.67
1. Each Dwelling unit will be required to be protected with Surge Protection 230.85
1. Each dwelling unit will be required to have an emergency disconnect on the exterior of dwelling
