Michael15956
- NE Ohio
Post some troubleshooting jobs or questions so I have somethings to read.
If there was power in the box at all times, you used the pull chain switch on the fan to control the fan and the switch leg to control the light(s).Read War and Peace-- that will give you something to do....:lol:
I got a call from a guy who had 3 electricians come to his house who told him the only way to do the job he wanted done was to open the walls.
The room was on the second floor of a 3 story finish apt. There was one switch and a ceiling fan -- one switch leg- The light came on with the fan but he wanted to put a track light on the ceiling about 2 feet off the wall. He was okay if the light on the fan and the track came on together but he didn't want the fan to operate at the same time.
I thought it was a no brainer- took us about an hour -- no drywall repair. What did I do?
I was called to site one Saturday morning because of a "thumping" noise coming from a DC variable speed drive. It sounded like a misfire. It wasn't.
Can you guess what it was?
An AC motor?
That's easy. You slid some white insulation on the EGC and used it as the neutral, used the black as always hot for the fan, and colored the original white with red to use as the switched leg. Then you tapped the white and red to feed the track with a fished cable.
Ceiling paddle fan- don't know if the motor is ac or dc but I suspect ac
He said DC variable speed - doesn't sound like a ceiling fan to me.
I didn't realize you were responding to Bes
Didn't his quote appear with my response? I can see it.
What about my guess to your solution?
DC drives and motors. About 200kW beasts.An AC motor?
No your answer is not correct to my question
Are we correct that the feed is to the switch box, not the ceiling box, and only two conductors between them?
Went to Lowes and bought The electronic switch and fan receiver.
I was expecting something creative. :roll:
Yes, I believe it, I can't count the times that has happened for me too.... I, the electrical designer, ended up solving a mechanical problem.
Can be a funny old world at times.
