hhsting
- Glen bunie, md, us
- Junior plan reviewer
Right, they may just be using that because it's super common, doesn't mean its a grounded system with a neutral.....but there appears to be a ground wire (SSBJ) going to the utility which implies it is, 250.86(B) . You need clarification from the utility what kind of system it is, and the designer about the grounding connections. Often not all grounding connections are shown on drawings.
Will ask the designer and let you know but 250.186(A) and 250.186(B) are about AC grounded system just one is neutral brought and other neutral is not brought. Also I dont see Article 250.86(B)? You mean 250.186(B)?
