cottora
- Atlanta, GA
"Six Throws" Grouping of Service Disconnects via (6) Inside 42 Circuit Load Centers
I am a little confused about the six throws rule for service disconnect. I do not believe that all throws must be in a single enclosure, but I am not sure if a grouping of Main Breaker Panels is acceptable. Below is the general setup:
There will be six conductors/feeders that originate at the low side transformer and each conductor will land in a 600 amp Main Break Panel (each panel has ~42 circuits). These panels will be grouped inside and readily accessible (open the door and there they are on the back wall).
The be clear, you can essentially stand in one place, open six doors, throw six breakers, and all power in the building is disconnected.
Thanks!
Thanks!
