Voltage Drop across size five starter M coil @120V
What is the distance you are concerned with? Use the full 1158 watt or 9.7 amps for starters. That would be more than adequate.
Somewhere in the specs it should tell you the pickup, holding, and drop out voltage for that starter coil. That will give you an idea.
The distance is around 1000 feet - the 9.7 amps would be momentary - couple cycles(?). I will dig a little deeper for the vendor info on this one.
