The panel was installed first by other contractor and I was contracted to finish out fitting space. I always thought you needed 15 inches left or right from center of panel.
So if a wall is right up against the panel on either side it seems it would be not so easy to install a wire on the circuit brk. because of the angled offset on the breaker.
