juant1971
- Orlando Florida
- Temporary Power Distribution
I just moved in to a brand new home, before moving in I decided to clean the floor tiles. Noticed that the master bath lights dim pretty bad when I turned on the vacuum which was plugged in the master bedroom. There is a overhead shower light, 2 exhaust fans, toilet light, and 2 light fixtures which hold 3 LED light bulbs each at 9 watts, this in addition to 2 closet fluorescent light fixtures all the receptacles and the overhead ceiling fan in my bedroom and all are on the same breaker. Just using the light fixtures and nothing else on the lights dim pretty bad is this normal or can there be something I need to investigate further.
This issue came up as soon as I turned on the vacuum with just the bathroom lights on, no other load was present besides the vacuum cleaner. I do understand that there is inrush current taking place, but is there anything I can get checked out or is this something absolutely normal to expect from this situation. This is all on a 15 GFCI/AFCI dual breaker in the panel using the normal 14 AWG wire. I don't really get how this type of install can make it thru inspections as this does not look like something very safe in my opinion. This is also happening in my hall bath and second and third bedroom which are also connected in to a 15 AMP dual breaker just not as bad as my master bathroom.
