Hi All,
I have been reading up on splicing service cable and feeder cable. I was curious if the splices needed to be irreversible or not. The only wiring, I can find, that needed to be irreversible is the GEC. If you splice into it. So if I am reading the code correctly, you can use split bolts. 230.46 and the the articles it refers you to say nothing about irreversible splicing. Is this correct?
Thanks,
Jim
2014 NEC
Thanks,
Jim
2014 NEC
