Looks like some Field Engineering may be required.Thank you for the input. Unfortunately it's not a despard switch plate. The switch box itself is single gang but about 12" tall. I have a picture of it. I just don't know how to post it or if it's even possible.
my thought also...Did they just mount a 3G box vertically vs horizontally?
my thought also...
That would only be about seven inches or so
OP said the box is 12" tall, so your idea won't work. Unless you change the box, then you would have to patch the wall.Replace the switch and plate with a triple single pole switch and use a Dacora plate.
Google search ...
But also said it is "single gang". Not sure what he actually has unless it is a large volume box of some sort with a "1 gang opening"OP said the box is 12" tall, so your idea won't work. Unless you change the box, then you would have to patch the wall.
I can't remember the name, but there is a site that will make any kind of wall plate you want.
I think I know what you are talking about, three standard size switches, not side by side, but stacked top to bottom? That would be about 12". Couldn't find anything on the web, but may not be using the right search term. You probably will need a custom made plate for that. Seroiusly doubt anybody would have NOS on that.Thank you for the input. Unfortunately it's not a despard switch plate. The switch box itself is single gang but about 12" tall. I have a picture of it. I just don't know how to post it or if it's even possible.
I seen a custom made box in a church built in mid 60's around here - probably 10-12 switches in same box in two rows with a custom made brass plate that covers it all.I think I know what you are talking about, three standard size switches, not side by side, but stacked top to bottom? That would be about 12". Couldn't find anything on the web, but may not be using the right search term. You probably will need a custom made plate for that. Seroiusly doubt anybody would have NOS on that.
