Neutral Needed
Alwayslearningelec
NJ
Estimator
For the 3P 100 breakers feeding the UP panels. It is just 3 phase conductors and no neutral? Why isnt a neutral needed?
You panel schedule shows all 120 volt spare circuit breakers and clearly states 3Ø, 4 Wire which includes a neutral.
True, but that has nothing to do with loads on the UP panels. We don't know what they are, at least I don't.
I'm thinking that it doesn't really matter whether or not there are neutral loads, the schedule clearly says 4W or 4 wire which is what the OP is asking.
If you base your answer on the question you thought you were answering I would say you were correct. :)
Yeah, this panel is UP-33A which requires a neutral. Not sure where is says that the other panels 33B and 33C do not require a neutral. It likely would not tell you that on the UP-33A panel schedule.
Agree. Going back to my original question - Where does it say a neutral is not, or is for that matter, required for the 100A-3P breakers feeding the other UP panels? The schedule for the panel we can see obviously has one.
Yes it is a 3P4W panel but why should that have anything thing to do with the load the breaker is feeding in that panel?
