Joncampos3
- San Antonio, Texas
- Electrician
Does it make sense to put a photocell on a light with a wall switch? Just wondering how this will work in this situation.
So it won’t work ?The light won't come on if the PC 'sees' enough light.
So it won’t work ?
......Switch off, it is motion triggered only. ..........
Depends on whether it's in series (override off) or parallel (override on).How does that work? If the switch is off, the power is off to the light......
No, I'm talking about a wall switch used in conjunction with the photocell-controlled light.Huh?
Are you saying power is always supplied to the electronics of the sensor... the switch just bypasses it and feeds power directly to the lamps?
Either would override the light off.If you turn the light off, then the PC doesn't have power.........
Or are you powering the PC, then putting the switch in the output of the PC?
To override the light on, you'd have to power the PC and wire the switch between the PC black and red wires, bypassing it.
If you'd like the light to come on and stay on all night long every night and not have to think about it I guess it makes sense.Does it make sense to put a photocell on a light with a wall switch? Just wondering how this will work in this situation.
Some motion lights with have a way to override the on/off. Usually you flip the switch off for a second or so then back on. The light will stay on until daylight, then at dark it will resume normal operation. Also, if you want to revert back to automatic operation after you have overridden it, you turn the switch off for about 15 secs then back on. It will stay on for close to a minute then go off and resume normal operation.Never really thought about using a switch to bypass the photo cell for constant On
