Simple question about pvc coated rigid.
I cant find anything in the code about pvc coated rigid specifically. I imagine that its just briefly mentioned in passing in article 344.10(D) and wanted to get either clarification, or a point in the right direction in the codebook.
Sent from my SM-J337V using Tapatalk
Special shoes are required for bending rob roy. The slightly larger O.D. will not fit into standard rigid shoes.
Sent from my iPad using Tapatalk
If you are not doing a lot of it, you just bend it in the next larger shoe size.
And a lot of patience. I used EMT shoes for coated RMC, IE 3/4" would bend 1/2", of course you couldn't bend 2" coated.
That way we had a set of shoes for EMT
Is this the same issue for ocal and plastibond, or just robroy?
It is an issue with all of them. The thicker the PVC coating, the more there is a problem. Most bending companies make mention of this.
