FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
Here's a dual recept yoke (logical hot-neutral), on left is each recept fed from same pole, on right is each recept fed from opposite poles.Reduce the magnetic field how? Or, two ask it another way,,, in what way is the magnetic field increased? You would have balanced current hot to neutral on circuit A1 and balanced current hot to neutral on circuit A2, there is no net current.
X and dot are typical arrow representation of current directions, X is in, the dot is out. Obviously they flip at 60Hz, etc.
The config on right has a more symmetrical mag field cancellation pattern then the one on the left.
It also applies if two duals are mounted in same box side-by-side, with each dual being fed from opposite poles.
