So I understand there is only one dimmer permitted on a 3-way circuit. I roughed in a residential kitchen and the carpenters used shiplap paneling, and I can not gain access to behind the walls... with that being said, I have a set of 3 way switches, one being the dimmer, and the other being a standard 3 way toggle.... *at the location of the dimmer*, I have the power coming in, the switch leg up
To the light, and a 12/3 wire running to the toggle switch... I had wired the dimmer and toggle accordingly, I think? The light powers up, however will not work once I shut the light out using the toggle... am I SOL considering the switch leg comes from one end instead of the other?? Help!!!!
