brett Harsha
- Portland, OR
- Senior elec designer
This is a panel and and a sub panel that is not properly protected with a main breaker as it appears it has more than 6 disconnects . Can some one identify what I believe to be a improper grounding since the service ground seem to be bonded to the ground bus in the sub panel. can't tell how it is bonded to a ground rod or any other grounding electrodes.
can you install a AFCI with out installing a ground to the receptacle.
This house has 3 prong outlets but no ground conductors to the outlets is that permitted by the NEC?
.https://docs.google.com/document/d/1J2ojpy_hJ0VyKbxweGXYmiLoEjKRNswvc_PT6YMJOBs/edit
