Jerramundi
- Chicago
- Licensed Residential Electrician
My 2014 Handbook has an interesting "author commentary" that's swaying me in your direction Larry.Then what does "single voltage, two wire secondary" mean, and why bother mentioning it?
Albeit not technically "code" and only "author's commentary," it says....
1. A transformer with a 2-wire primary and a 2-wire secondary...
2. A 3-phase, delta-delta...
Except for those two special cases, transformer secondary conductors must be protected by the use of OCPD's...
"Special case" to me implies a rare circumstance, which is swaying me in the direction of Larry here that "single voltage, two wire secondary" means a transformer quite literally with ONLY two wire leads coming off the secondary coil and the capacity to be wired for only a single voltage output.
It would in fact be a "special case," because I haven't been able to find any transformers with ONLY two wires coming off the secondary coil and ONLY the capacity to be wired for a single voltage output.
It seems most products come with the capacity for at least two secondary voltages...
