PowerMan2020
- virginia
- electrician
....but I have always used them with EMT with a set-screw connector. Plus if I use it outside I simply use a rain-tight compression connector for outside use.
So are all these threaded LB's (such as the ones found in HomeDepot with the Rigid Sticker) actually only listed for Rigid and IMC and could technically fail jobs if using them with EMT?
