Three pole 20 A breaker for six 1000 watt hps lights
Dugger
New User
Oklahoma
Electrical Contractor
I have 240 volt 1000 watt HPS lights. Is there a problem connecting six of these to a 3P20 breaker? I have a 240V delta 3-phase system.
240V 1000W HPS lights are a pain. Unfortunately you cant connect 4 on a 20A circuit because they are around 4.4A each (277 works good for these as you get 4 per 20). So you are looking at 3 per two pole 20 breaker. How exactly were you proposing to connect them to a three pole breaker?
Am I missing something, he wants to connect 6 luminaires, if they do draw 4.4 A each then you would put two between each phase and have 8.8 amps. That x 1.732 because of what is between the other two phases gives you 15.24 amps on each of all three phase conductors.
