Ozymandias
- Missouri
Hi all,
I have a job where I have a 200A fused disconnect with two phases(208/120), the neutral and ground. I will be running feeders a 120' away to a panel which will feed rows of refrigerators.
Is it permissible to use two phases out of the three?
I assume so since that disco fed a panel which is no longer there, and because only two phases are available could I use a 240/120V panel.?
A three phase panel would only have two buses energized. On the 240/120V panel, only 120V circuits would be used from the panel, I understand I would only have 208V available instead of the usual 240V. Thanks for the input!
