I'm changing a panel that was put in 40 some years ago. There is no equipment grounding conductor in panel. Panel is bonded, but there is a Disconnect outside by meter, so really this is a sub panel should have 4 conductors at panel instead of 3. Can I just use conduit as my equipment ground per 250.118 and separate the grounds and neutrals. This is a apartment building unit is on second floor.
