yesterlectric
- Texas
- Electrician
For a motor operated appliance, such as a sump pump, does anyone know if, when using a molded case circuit breaker for the disconnect required by article 422, if that breaker must be switch rated SWD? Article 240 simply says breakers must be switch rated or marked SWD when used as switches. There's no qualification though, of what is considered being used as a switch. In theory, every breaker is probably used as a switch a few times in its lifetime. The intent of the code, I think, is to ensure breakers aren't being used to turn a load on and off daily, but I don't think it clarifies that so well. As a result, something like this could be up for interpretation and debate, it would seem.
